Converting vi's from labview 7.1 to 6.0 without using 7.0
I have some code written in labview 7.1 and I need to run it on a computer running Labview 6.0. I have found the save for previous version, but that only gets me to version 7.0 how can I save the files as older versions without having a copy of 7.0 and 6.1?
Thanking you
Dishy
(2,598 Views)
With out a copy of labview  7.0 & 6.1  you are up the creek with out a paddle my son !!
Suggest you see if anyone can help by converting to an earlier version.
Failing that have you thought of  starting a fresh.
Regards
xseadog
(2,593 Views)
