Converting visa outputs to numbers
Labview is currently recieving data from a device (through visa) as a string in the format NA[ ][ ][ ][ ][ ][ ]cr, where the first [ ] is a +/-, and the follwoing five [ ] is a 4 digit number with one decimal place.
I need to convert this to a number that only contains the [ ], and have not been able to find a solution
thanks!
(3,446 Views)
See this.
This is a pretty basic operation. Have you taken the LabVIEW 101 tutorial?
(3,432 Views)
Accepted by topic author DARB
Hint:  Look in the strings palette.
You have access to String/Number conversion function.
(3,410 Views)
Thanks Ray.R
I ended up using the fract/exp operation.
(3,390 Views)
