Convertion Hex String to 32bits Decimal floating point??
I would like to know how to convert hexa like: 416b0ac3 in decimal 32bits floating-point. The result of this string is suppose to be 14.690127.
So i must be able to do:
From 32-bit Hexadecimal Representation To Decimal Floating-Point
Thanks for your support
RiderMerlin
(8,317 Views)
RiderMerlin
You can use the typecast function to do this.
David
Message Edited by David Crawford on 09-06-2006 03:31 PM
(8,305 Views)
First thanks for your fast answer,
Just for a information (i'm new around Labview); what's the SGL icon? Is it a numeric value?
Ridermerlin
(8,291 Views)
Sorry,
I got my answer!
Thanks for your support it's working very good! Smiley Happy
Ridermerlin
(8,286 Views)
Its a numeric constant. You can find a numeric constant in the numeric palette but its blue which is integer so that might be throwing you. Drop the constant onto the block diagram, right click on it and change its representation to single.
David
(8,283 Views)
