Convertir un caracter ASCII en bitmap
Hi, I'm looking if possible through labview, enter a character on the keyboard (with the characteristics of the selected source) and create a bitmap for further processing.
Perhaps one of the few things that can not be done because I've time searching and find nothing about it.
I appreciate any ideas or comments, greetings and thanks for your attention.
Hola, estoy buscando si es posible mediante labview, introducir un caracter del teclado (con las caracteristicas de la fuente seleccionada) y crear un fichero bitmap para su posterior procesamiento.
Quizas es una de las pocas cosas que no se pueden hacer pues llevo tiempo buscando y no encuentro nada acerca de ello.
Agradezco cualquier idea o comentario, saludos y gracias por vuestra atención..
(3,163 Views)
Accepted by topic author tecnico.bcn@gmail.com
Hi tecnico,
- you can enter any char in a string control
- you can create "bitmaps" with the picture functions
- you can even write a char into a picture using the picture functions...
Maybe you should explain your question in more details?
(3,155 Views)
Hi GerdW, increible, it was very easy and i was thinking in complex systems.
Thanks a lot for you help.
Best regards
(3,150 Views)
Hi again, the result is good if i use a size of font upper from 12 size, but if i use a Arial 7 size i can't write any .bmp file.
Some more new idea?.
(3,130 Views)
Hi tecnico,
I wouldn't use Arial 7.
Use some bigger font sizes - or use a "pixel" font like "Small Fonts"...
(3,118 Views)
