CoolSNAP HQ from Roper Scientific
If anybody has experience with the CoolSNAP HQ camera from Roper Scientific and LabVIEW 7.1: Is there any alternative to the SITK from RCubed for basic imaging functions? The SITK seems a bit overkill for our application.
Thanks in advance,
 John
John Breneman
Lawrence Livermore National Laboratory
breneman2@llnl.gov
(4,305 Views)
Hi JBrenem,
Thank you for using National Instruments forums.  Granted, I am from NI; my suggestion may be a little biased.
I personally have never used the SITK, but if the camera that you are using from CoolSNAP HQ is the RS-170/PAL selectable output camera (was the one I quickly googled), you would be able to use any of our analog frame grabbers to be able to do a basic snap/grab using our driver to take it directly into LabVIEW.  If this is the case I would recommend looking into the PCI-1405 as a potential solution if cost is a consideration.  If multiple cameras or triggering ability is more of a required feature, the PCI-1410 is a great solution for that.
I hope this suggestion can help you out.
Justin Louie
(4,284 Views)
Thanks for the reply jlouie! The CoolSNAP HQ actually comes with its own frame grabber which does have a SDK (PVCAM) available. Sounds like this thread is describing what I'm trying to do:
 http://forums.ni.com/ni/board/message?board.id=170&message.id=36202&requireLogin=False
 I guess what I really meant to ask was, are there any LabVIEW wrappers for the Roper Scientific PVCAM SDK around besides this one:
 http://www.roperscientific.de/LabView.html
(4,274 Views)
