10-09-2006 08:45 AM
10-09-2006 09:32 AM
10-09-2006 10:17 AM
Thanks a lot, this helped me very much. Now I can use the cursor. But one small question. With the program I used I was able to put a picture in the background of the plot. Is it also possible with the XY-Graph you mentioned from the other thread?
Once again thanks a lot
Joerg
10-09-2006 01:19 PM
I see now. I forgot that the VI you mentioned uses the picture control (the blue wire) and I couldn't look at the code before.
Basically, you have a problem because that method would only work on a graph control and you can't put a picture into a graph control. You can either color the graph transparent and have the picture under it or use the method I suggest earlier for calculating where you clicked. If you open my attachment here you should be able to modify this example to work with the picture control (although you will have to get some of that data not from property nodes).
10-09-2006 01:39 PM
