Copies of Sub VI's created in a case structure returns a zero array.
The original sub VI returns a finite value in the case structure.. However when a copy of the subVI is created for different values of input in the same case structure, the output array is indeterminate. Please send in your solutions to abhardwa@engin.umass.edu.
(2,683 Views)
Maybe you can attach a example program that demonstrates the problem. We cannot thell from your decription what is significant or even what the problem is.
  • Why do we need to crete a copy of the VI (I assume under a different name)?
  • What if you feed "different values" to the original VI, do you get the same undesired output?
  • What is "indeterminate"? (empty array, array of zeroes, array of NaNs, etc.)
  • What is in the different cases of the case structure?
  • Are some output tunnels set to "use default if unwired"?
  • What is your LabVIEW version?
In general, answers should be posted here in the forum so everybody can profit from the solution. Providing solutions via private e-mail should be strongly discouraged. 😉
Message Edited by altenbach on 10-23-2005 10:44 AM
(2,681 Views)
hi..
*  the LabView version i'm using is 7.1
*  the indeterminate array is an null array (array of zeroes)
*  when a different input is wired to the original SubVI, the expected waveform is predicted.
*  the case structure represents different inputs which are wired to the same SubVI in the 2 instances.
hope this should be of help.
(2,669 Views)
Sorry, It is not clear what you are saying:
  • Do you simply have a second instance of the same subVI or do you create a copy with a different name?
  • What is the size of the "array of zeroes", ... or is it an array of zero lenght?
You should attach an example of your code to make things clear?
(2,666 Views)
