Copy Paste multiple rows in multicolumn listbox
Copy Paste multiple rows in multicolumn listbox.I have an application developed for scripting in Labview I have used multicolumn listbox and on Add button action I add my predefined commands in multicolumn list box.
However i wish have copy paste facility by which i should be able to copy and paste multiple rows at a time any where in between or at the end
(3,419 Views)
Hi uttara,
If you check "1 or more" in "Selection mode" property, you will have an array of chosen values, and you can use it to gather the data from property "Item Names". Example VI is Attached.
Mariana.
(3,408 Views)
