Copy VI from LLB.
Is there any way I can copy a VI from a library(llb) to a different directory?
(4,701 Views)
If you mean progamatically, see http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000002200000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0. If you mean from the development enviroment, just open the VI and do a Save As.
(4,701 Views)
Inside LV you can open it and use Save As... to save wherever you want: in a separate directory as a standalone VI or in another LLB. Make sure to check the Make a Copy checkbox at the bottom of the dialog window if you don't want to chain the new location of the VI to all its callers (this could cause 'VI not found' errors in case you move after that VI outside LV or delete it).
I don't know of any mean to do the same outside LV, in case this is your actual question.
Roberto
(4,701 Views)
[LV5.1] You can use the "File Manager" located under Menu bar --> Project.
[LV6] This tool is now named "VI Library Manager" and you will find it in Menu bar --> Tools. Originally NI forgot to implement it in the LV6 FDS. But this was corrected with the 6.0.2 patch.
(4,701 Views)
