Copy a shortcut to a file using LabVIEW?
Try File Manager at:
Message Edited by zou on 08-31-2005 02:01 PM
George Zou
Message 11 of 20
(4,218 Views)
Message Edited by zou on 08-31-2005 02:03 PM
George Zou
Message 12 of 20
(4,218 Views)
Oops.
How do I delete a post ?
Message Edited by zou on 08-31-2005 02:04 PM
George Zou
Message 13 of 20
(4,217 Views)
It works fine an a computer with XP pro and doesn't work on a computer with XP home.
For some reason, home seems to ignore the /c switch attach to cmd, not sure why.
hmm...
Other than that, there appears to be a bug (although pro doesn't seem to mind). Now that the full path is given, there is an extra backslash.
___________________
Try to take over the world!
Message 14 of 20
(4,317 Views)
Yups tht is wat I mean,...........I am not able to link to the original file for which the shortcut is created...
Message 15 of 20
(4,183 Views)
Hey all !!!!!!!.....
                       I got the method to copy all your .LNK files ....to any location ......just workes a little on tst's "copy lnk.vi", & it works.....the only problem was with white spaces...poor cmd does not recognise ...white spaces...so it returns "file not found".....BUT now it does.....!!! Chk out the attachment....!!Smiley Wink
Message 16 of 20
(4,267 Views)
Was this bug ever resolved?
I have LV 2009 and I am having similar problems.
I have the overwrite set to false.
When the execution gets to the link file (.ink), it stops and gives a error.
 code = 1
text error is:
Copy in CopyMyDocs.vi<APPEND>
G:\Backup\12.7.2009\MyDocs\My Documents
If it continued would not be a big deal, it's just a shortcut.
Message 17 of 20
(3,696 Views)
can i get this example in labview 8.0..please..thank you
Message 18 of 20
(3,645 Views)
Still seems to be the case in LV2019...
At least when copying a folder that has a shortcut in a subfolder
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 19 of 20
(3,006 Views)
It’s not a bug at all but a feature. When you specify a path with a .lnk file in it, the LabVIEW path will always be resolved to the real path before trying to do any file operation on the path. The only way to treat lnk files as actual files is by avoiding the LabVIEW path datatype entirely. But the lnk file is a DCOM based extension of the Windows shell, not the lower level Windows API. This means that if you copy a link file to a different location with low level Windows APIs or the command line tool it will generally not point to the original file, since that location is stored in relative form inside the link file, which will then point into nirvana relative to the new location.
There are some shell32 Windows APIs that can properly deal with lnk files but they generally work on IDLists, another marvelous invention of the early Windows Internet Explorer developers who thought to invent a completely novel file system view on top of the Windows 95 volume system. Only to be overtaken by the Windows NT guys who developed a real new file system management onto which the old DOS system was mapped to, rather than the other way around. But by that time the bad had already happened and the not really officially documented Win95 pseudo file system was moved info its own shell32.dll together with lots of IE crap and under a court order also officially documented. The rest is history as they like to say.
The whole is a total mess of inconsistencies, compatibility hacks and half documented features. I’m sure  that the LabVIEW developers brainstormed many times about how to solve this properly and that there was no satisfactory solution that wouldn’t have meant to introduce a whole palette of extra file primitives and/or rextra enum parameters to every single file IO function. Add to that the fact that the Windows link files have significant semantic differences to Unix symlinks and Windows despite having low level support on NTSF for symlinks since at least Windows XP, even Windows 10 doesn’t support them on user level as fully supported entity. The explorer can deal with them but if you want to create them you have to resort to 3rd party tools or the command line! And they are so dangerous that under Windows only an elevated account is allowed to create them by default!
Rolf Kalbermatter  My Blog
Message 20 of 20
(3,000 Views)
