Copy and paste from block diagramm between labview versions
I try to reuse some code from labview 2015 in labview 2013 (because i need that code with an 13 compatable rio).
Therefore i simply tried to copy and paste BD elements hitherho.
It ended up that the BD elements were pasted as bitmap instead of the original objects.
Do i have to use some different copy and paste possibility than strg-c and strg-v or do i have to save each sub-vi as 2013 which would
make much unneccesary work?
(3,021 Views)
Accepted by topic author Labuser16383
You can't copy + paste between LabVIEW versions.
You'll need to save for previous version and open in the LabVIEW version that you want to paste to.
(blog)
(3,005 Views)
