Copy files with LabVIEW to the printer.
I try to copy a generated file with the copy-method from LabVIEW 6i to
the printer. The same aktion out of the dos box works, but the
copy-method from LabVIEW 6i dosen't support this function. I'm running
LabVIEW under Windows NT 4.0. Can anyone help me with this problem?
Jens
(2,869 Views)
If you want to print files, you can call windows API's. The associated
program will print the file (e.g. Notepad will print .txt files).
I'll send you a VI to do this if you like.
Wiebe.
"Jens" wrote in message
news:e3472b85.0210172151.4293e29d@posting.google.com...
> Hello,
> Jens
(2,869 Views)
