Copy function results in Error 1430 when the target path terminal is <Not A Path>
Hello all.
I'm having a little bit of trouble with the Copy function under LabView 8.2.  If I wire <Not A File> to the target path terminal, I get an Error 1430 (The path is empty or relative.) from the Copy File function's error out terminal.  According the the manual, wiring <Not a File> to the target path terminal should cause the Copy function to display a dialog box prompting the user to select a file.
I've attached a sample VI which demonstrates this issue.  Is the documentation for the Copy function incorrect, or is something I'm doing wrong in my VI causing the error?
Mark Moss
(3,009 Views)
Hi Mark,
Thanks for bring this to our attention. I believe the documentation is incorrect here, as you suggested. When nothing is wired to the target path terminal, it behaves as expected (prompting the user to select a target directory).
I will look into this further and report this issue to our LabVIEW documentation team.
Sam
-Sam F, DAQ Marketing Manager
(2,991 Views)
That's what I figured.  It was easy enough just to throw a cast structure around the Copy function and leave the target path terminal unwired when I have Not a Path.
Mark Moss
(2,983 Views)
