Copy image to the front panel from file
Hi all
Help me anybody
How can I copy the image from file to the Front Panel via Block Diagram?
Best regards
Iskander
Message Edited by Iskander on 02-20-2009 12:55 PM
(3,819 Views)
Where on the front panel are you trying to place it? As the background, or as a pasted image? For a background image, read the image using the graphic format Vis and then write to the BackgroundImage for the primary pane:
I'll leave the other option as an exercise for you. Smiley Wink
Message Edited by smercurio_fc on 02-20-2009 01:45 PM
(3,805 Views)
Accepted by topic author Iskander
Hi
Thanks very much
all are working
Respect
Iskander
(3,794 Views)
Then perhaps you should mark my reply as the solution rather than your thank you post. Smiley Wink
(3,791 Views)
