Copy project breaks class variables
Most of the things you described I have already learnt (the hard way). I have never experienced the constant-typedef  issue until now, but since I now know what is happening I can work around it.
Your last post nicely describes a few steps which should be followed.
Message 11 of 13
(863 Views)
If you look at clusters as objects, it's just a small step away from OO.
I have >3000 VIs, and a hand full of clusters at most. Well, I have clusters, but they're in the private data of classes.
Classes define type and behavior. The behavior (that can be inherited) is the big bonus OO provides. A side effect is that classes are always in memory when the project is loaded. That works well for me; if somethings is broken, I'll know because it's in memory. And when something is changed, everything is updated because everything is in memory.
It took me 8 years to take the leap, and 1 weeks to start appreciating it, 1 month to love it...
Message 12 of 13
(857 Views)
We also extensively use OO as well. I didn't suggest that because it seems to scare most folks off. However, once you understand it is very powerful. Definitely worth taking the time to learn.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 13
(839 Views)
