Copying Labview files onto another computer
Why doesn't Labview work when I run it on another computer with the exact same data files that I copied from the original computer? To be specific, some of
the VIs are missing.
Thanks for the help!
(3,595 Views)
If you can tell us what vi's are missing it would help determine what the issue is.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,583 Views)
Do you have any toolkits installed on the first machine and not the second???
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,578 Views)
I am missing my buffer XY graph VI. When I tried to get it from Control Design & Simulation again so that I could rewire things together,I wasn't able to drag the Buffer XY graph onto my block diagram.  Any ideas?
 I don't think the second computer is missing any toolkits.
(3,527 Views)
Hi mcypang,
Do you get any errors when trying to drag the VI onto the block diagram?  I'm assuming your dragging from the functions pallete, no?  You can check in Measurement & Automation Explorer (MAX) to see if CD&Sim is installed - look under software >>Labview.
Kristen H.
(3,480 Views)
