Copying Probe Data To Notepad
Hi everyone,
A lot of times when debugging code I want to copy probe data to notepad (text file).  I right click on the probe data I want to copy and select "Copy Data" but when I try to paste the data into a text file it doesn't paste.  Is there a way to do this?
Thanks so much!
(6,820 Views)
"Paste" the data from the probe watch window to a blank vi Block diagram rather than notepad..
Actually that's probably a little known feature of the PWW.  But it works wellSmiley Surprised
(6,813 Views)
Thanks Jeff Bohrer.  Sometimes though you want to send this information over to someone else while trying to debug code.  Is there a way to pull the data from the Probe window and into notepad?
(6,781 Views)
Not that I am aware of but, That's what gotomeeting is for.  get someone esle right on your machine
(6,754 Views)
You might vote for this idea - Right-clic​k -> Copy Data should copy TEXT data
Jim
(6,728 Views)
Hi all,
I'm no expert and as I regularly rely on the many good folks on these forums to help me out, I thought I'd take the opportunity to share how solved this as I don't often have much to contribute.
My approach...  "Copy Data" from a right click on the probe...  paste it into blank VI... wire it to "Write to Spreadsheet File VI"... gave it a filename...  and run it.  Then opened the resulting file in Notepad and begin copying and pasting to your hearts content.
Cheers, Iain
(6,157 Views)
