Copying and pasting array values
I have a program that has multiple arrays.  Recently there were about 80 more new values I needED to add to each array.  I just finished adding the new values to one of the arrays - is there a way I can highlight and copy that whole block of values I just added so I can then paste it  onto the other arrays?  It seems like I can only highlight, copy and paste one value at a time.
Amateur programmer for over 10 years!
(4,651 Views)
Accepted by topic author spaceman_spif
Do it programmatically.  Copy your array to a new VI.  Use Array subset to get the portion.  Add it to a copy of your other array with Build Array or Insert into Array.  Copy the updated arrays back to the original locations.
(4,640 Views)
EDIT.  It doubled posted message.
(4,639 Views)
I was considering that, but I found these new values are all the same for each array, so I was hoping there was a way to do a simple copy and paste.
(4,630 Views)
