Copying files from VSS to a client comp
Hey guys, im looking for a way to copy my entire VSS project down to a client computer.  I can get the main project but not all of the subprojects.  Its not technically a project but the top level VIs are in the common folder then all the sublevel VIs are in folders below the common folder.  Whenever I try and "Get Latest Version" it only gets the files from the common folder (top level VIs).  Is there anyway that I can get the whole project together including the sub projects while mainting the folder hierarchy that is set up?
Ive looked and looked but just can't seem to find anything.
TIA
Jason
(2,617 Views)
Try it using the Check Out instead of "Get Latest Version". In the appearing dialog should be a checkbox labeled "recursive" - check it and VSS should check out the complete hierarchy.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,614 Views)
Hey Thomas thanks alot man!  I had seen that recursive option but I had no idea what it meant.  That fix worked like a charm.
THX!
(2,612 Views)
