Copying text files to flash card (Palm LB7.1 PDA)
Has anybody had experience of copying text files saved as records from Palm main memory to an expansion card? I'm using a Palm 515 running OS4.1 with an MMC card.
There's no mention in the PDA support docs that the copy or move VIs don't work with Palms and they're ok with Pocket PC.
I can write a file to the card using the path card1:// (eg card1:/abc.txt) with no problems, but moving or copying doesn't seem to work when using the target path card1://.
If anybody has had success doing this then I'm doing something wrong!
Cheers,
(2,740 Views)
I've nothing to answer to you but ...
In fact, I'm interest in your solutions if you got one ?
More i' really can't use my SD Card correctly i tried "card1://toto" or "card1:/toto" but i've never been able to write something on it ! The file stay created on the palm Card. (I've linked a "simple string constant" to a "string to path" function then to a "New" vi.)
Another question : Is it posssible to get the list of content of (DIR) of the SDCARD ?
Than you if you got answers for me
(2,708 Views)
