Core 1 Training
Are the two Core 1s below the same?  If not can you tell me how they are different?
Thankyou
Chris
(2,055 Views)
How do I get an answer to this question?
Hello McFly......
(1,971 Views)
Can you explain what the 2nd picture is? It looks like it is from the training portal.
The Core 1 curiculum should be mostly the same, but it's been done in multiple languages and with different versions of LabVIEW. If you already have access to it somehow, it's probably not worth buying a slightly different version that used a different version of LabVIEW.
(1,955 Views)
It is from my learning library
(1,947 Views)
