Correct termocouple reading by VI channel test panel but not by DAQ wizards.
1. I am getting correct termocouple readings when using the virtual channel test panel, but not when using labView software created by the DAQ wizards. why and how to solve it?
2. I am unable to switch on 6V relay using DAQ card's output voltage but able to do so using other voltage supply. How to solve this?
(2,603 Views)
In answer to #2, the DAQ card's analog and digital outputs cannot drive
enough current to turn on a relay. What you need to do is use the output to
drive a MSOFET or transistor that will drive the relay. You can use the 5V
computer supply that is available on the DAQ card connector as the power
supply that the MOSFET or transistor use to turn the relay on.
Neal Pederson, President, VI Control Systems
1923 Mendius Lane, Los Alamos, NM 87544
TEL: (505) 662-1461, FAX: (603) 388-4969
np@vicontrols.com, www.vicontrols.com
"DAQprojects" wrote in message
news:506500000008000000C11D0000-986697009000@quiq.com...
> DAQ
(2,603 Views)
