Correct time display
Probably a silly beginner-question but I can’t change a period of time in a chart further than 17 min!!! But the indicators show the correct time, no matter which period I fill in!
I think it has to do with the precision!??
At the end I want to be able to fill in various time-periods so that I can see the values stored between this beginning an end time.
Also it is not showing the values I generate! How come???
Please help,
greetings
(2,838 Views)
Hi
These two examples attached can be found in Labview examples
They give you an idea on how to use chart property nodes of x scale max, min, offset and multiplier.
also choose suitable x scale style.
regards
Dev
(2,824 Views)
