Correct way install DSC application to run-time PC?
I have developed application .EXE which use DSC toolbox. How I should "install" this .EXE to run-time PC? I have already installed DSC-runtime to run-time machine. In few libraries I use automatic data logging to citadel database. Should I copy citadel database to run-time machine or do I create new database there?
Because libraries includes reference to citadel it seems that I also need to edit libraries. That is quite tricky because there is no tools to do that in DCS run-time. I have build automatic library deployment to .EXE so that is not the problem.
BR, Jim
Message 1 of 1
(2,399 Views)
