Correctly handling a combo box output
A combo box will output one of two types of data.  If it finds the value entered on its front panel control in the strings column of the Strings and Values[] array, it will output the corresponding value cell.  Otherwise it will output the string.  So, if my Strings and Values[] array looks like this:
Red, 0
Yellow, 1
Green, 2
and I enter "Orange", then the combo box outputs "Orange".  If I enter "Yellow", then the combo box outputs "1" rather than "Yellow".
Is there any method to determine which behavior the control used?
(3,869 Views)
Accepted by topic author kc64
Actually, the datatype is always a string. The "value" needs to be interpreted as a numeric by you. Off the top of my head, you have 2 ways you can do this:
  • Use Search 1D Array to search the Strings[ ] property to see if the combobox's Text.Text property is in the list of strings. If the output of the function is -1 then you know it simply returned the string.
  • You can use the Decimal Digit? function to see if the value is numeric.
I'm sure there are others.
(3,860 Views)
Thanks, s.
Exactly what I needed.
(3,852 Views)
