Corrupt DataLog file?
Long time someone post something regarding the DataLog files.
You know, File I/O\ Advanced File Functions\ DataLog 🙂
Is it because it's "old skool" and there is something better now??
Anyway, allow me to ask this question.
I have several DataLog files, all of them I can read with the existing EXE file and LV development code except one Smiley Surprised
I always get the error code 71 when reading that specific file.
Since all files are made by one and the same LV EXE file I find that very strange.
I then read several files using note pad to get an idea about what's inside.
All files I can read starts with: DTLG €    #  !   $ @0ÿÿÿÿ
The one I can't read has the same pattern from character 146 onward.
I have no idea at all where those 145 characters came from ?!!?
"Ç  Started-20140508.dat C:\PROGRA~1\BEKAER~1\TIREIM~1\DataBase\STARTE~1.DAT    6   C:\Users\WU71AD~1.SHE\AppData\Local\Temp\STARTE~1.DAT ‘Å
The first readable characters are the name of the file, the following path's, no idea!
After the four ÿ characters I see the correct definitions of the cluster I use in all files, so that is rather good, I suppose.
Easy solution I tried, delete the 145 erroneous characters but then I get error 42 :  LabVIEW:  Generic error. when reading the new file.
Anyone an idea how to "uncorrput" this file correctly ?
All happens in LV 8.6
Thanks for reading
Even more thanks for a solution!
Best regards
Alain
Message 1 of 1
(3,009 Views)
