Corrupt globals.vi using git
I am developing a LabVIEW program using v2013 and I keep it under version control with git.
Recently, I tried to push a few changes to the repository from a computer with LabVIEW 2014. I added a new vi and changed the globals file.
Unfortunately, there is something corrupt about the globals file. Here is the behavior I observe:
- When I copy and paste a reference to a global in a vi that uses it, I cannot wire it to anything or change the global variable name (the gray selection menu does not appear). Double clicking does not take me to the globals.vi file.
- Any globals that were already in a vi behave as before: they are wired and you can select which global variable from the menu. Double clicking will open globals.vi file.
- When I try to create another global in the globals vi file using copy + paste, it is not editable (either the value or the name)
Here's what I've tried, with no change in behavior:
- reverting my changes to a previous commit (before I merged with the newer version of labview)
- recloning repository
- copying a version of globals.vi that was saved for v2013 (on the v2014 computer) and replacing the globals.vi file on the v2013 computer.
What should I try? I'd love to not have to rebuild the globals file from nearly scratch. Are there particular temporary files that need to be removed for globals to start to work again?
Kristen
(4,307 Views)
collaborate with the Git User Group
Kristen
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(4,300 Views)
I was able to "solve" this problem by updating to LabVIEW 2014.
(4,230 Views)
The best solution would be to not use globals, unless they are ones you write (FGVs, DVRs).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,221 Views)
