Corrupted TDMS File
Version 2.4.0f0
Josh
Software is never really finished, it's just an acceptable level of broken
Message 31 of 35
(2,035 Views)
Glad to see your problem solved.
By the way, the corrupted TDMS segment you attached could be opened successfully with TDMS 2.4.0f1. It's possible in some cases where TDMS segments are not independent with each other, they might be sane individually while have conflicts when combined
However, if it's convenient and you'd like your file be recovered entirely, would you please have a second check whether it's the corrupted one.
Message 32 of 35
(2,016 Views)
Well, it does open in the Excel importer and the Viewer, but there are no analog values.
(I can't open with Diadem anymore, my 7 day trial expired)
Josh
Message 33 of 35
(2,003 Views)
If I rewrite the file without this segment, would it work (and would it throw off my time for any points after the deleted segment)
Josh
Message 34 of 35
(1,999 Views)
well, thanks for the update.
Message 35 of 35
(1,988 Views)
