Could I use lvsound2.dll to write a 24 bits LPCM Wave file ?
I want to write my mulit-channel measurement data to LPCM wave file.
After I search NI developer Zone and this discussion forums.
I think maybe "Sound File Write (DBL).vi" is my solution.
But It only support 8/12/16 bits in LPCM format,
when I use 24bits to write a wave file, it's change to compression format "FF FE" (AudioFormat)
 "Sound File Write (DBL).vi" use "call library function node" to call "lvsound2.dll" to write a wave file.
Can I modify it to write a 24 bits LPCM wave file ??
or How should i do ?
(2,788 Views)
Try to search Google first "labview lpcm".
You may need 3rd party software.
As I know, you cannot modify lvsound2.dll because this is from NI RD.
Maybe next version of labview will support 24-bit.
(2,761 Views)
