Could anyone tell me how to convert digital waveform into 1-d array of digital waveform
 I am using 9474 for drving a motor. for that i am using 2 port - one for enable and another for run. These signals are in  the form of boolean values.  i am converting these signals into array and from that iam making a digital waveform. but when iam connecting these to the 9474 module it is showing an error "source is a  digital wave form and sink is  1-d array of digital wave form.. any body can help in these issueee plz...
(2,904 Views)
Accepted by topic author FSK
Pop-up on the wire and choose Insert ...
Build array.
Ben
(2,903 Views)
Thanks ben.....
Now the problem is i cannot compile it..........   I am attaching the sample code along with this.. any body can rectify it
(2,878 Views)
Replace the data input which you have on the front panel which is being converted from Boolean to Digital with a Boolean button and the vi will compile and run successfully.
Sahil Singla
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(2,859 Views)
