Count 4th consecutive pulses from the analog output of the encoder
Hi
Iam getting analog output from the encoder and i want to count the 4th peak of the analog signal. Kindly suggest the best method Once 4th pulse is detected counter will increments.
Pl refer the encoder output .
(2,804 Views)
What have you tried so far?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,802 Views)
Whatever you've counted using your logic, divide it by 4 and convert it to an integer (towards negative infinity)..!!
This should work.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,794 Views)
Hi
I am doing the same but I need to increment the counter when the 4th peak of the pulse detected. This is analog output not digital.
(2,790 Views)
Keep a total count of all the peaks.  Use the quotient remainder function for dividing by 4.  Whenever the remainder =0, you know you have a 4th peak.  Then increment your "4th peak counter".
(2,782 Views)
HI All,
This methos works.!!!!Smiley Happy
(2,761 Views)
