Count Events or Time.vi
I am a new user and faced problem using the Count Events or Time.vi found
in 1EASY IO.llb The vi was to count the pulse generated, which would range
from 0 to 50KHz or more. It was notice that the Count Events or Time.vi was
not able to count the pulse generated above 3KHz accuratelyt. Is this due
to the hardware limitation (eg computer too slow)? Is there any way of correcting
the error?
In addition, the Count Events or Time.vi would reset after 65536 counts.
Is there any possible way for it to reset at 360 counts or multiple of it?
Appreciate for any help.
Thanks a lot.
Choon Boon
(3,083 Views)
What counter are you using? Is the "advise" rate fast enough to grab a high
freq? Any "noise" filters enabled?
(3,083 Views)
