Count Pulses in Labview without a counter function
Hi All
Is it possible to count input pulses without a counter function?
I am using a Mydaq which only has one counter and it only counts up
If I can count without a counter function, I can achieve all I need to achieve.
I would need to be able to count up and down do
Please advise if this is possible and if so, how.....
Regards
Greg
(4,477 Views)
Got it Sorted...
(4,462 Views)
How? Can you please explain or help.
(3,870 Views)
I assume he found myDAQ's counter an count in both directions. Here is some more information about it: How Do I Use the NI myDAQ Counter?
Does this answer your question?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,854 Views)
Thank you for the reply but my query was if i can use other digital inputs as counters... As my daq has only one counter and i need to count pulses for 5 different inputs...
I am looking for solution in LabVIEW...
(3,851 Views)
Hi rishavpreet,
can myDAQ read DI signals with hardware timing?
Then set a sample rate large enough for your pulse signals, read those DI signals and count the pulses on your own from those digital waveforms…
(3,840 Views)
Hi GerdW
Thank you,
Solved it using Boolean PtbyPt block.😊
Regards
Rishav Preet
(3,837 Views)
