Count The colored fields of a 2D array
HI, is there a way to know hoy many fields of a 2D array are colored?
i want to count ta painted fields of this table
regards
Message 1 of 12
(3,812 Views)
You can use for loops to set the active cell and then read the background color for each cell using a property node.
Then just check to see if the color matches what you're looking for.
Rob
Message 2 of 12
(3,803 Views)
you mean put the array in a for loop in order to get the cells and with that set the active cell?
do you have an example so i can check it out?
thanks a lot
Message 3 of 12
(3,799 Views)
Accepted by topic author Tokyghy
You have to check each cell and see which ones have the color you're looking for. Sort of like this:
Interesting that it replaced the reference with a reference control. Data Table 2 should be a reference to Data Table.
Rob
Message 4 of 12
(3,784 Views)
Rob
Use the Code Capture Tool.  It doesn't have that problem the way the VI Snippet built into LabVIEW does.
Message 5 of 12
(3,781 Views)
THANKS FOR HELPING 😉
Message 6 of 12
(3,757 Views)
I have a 1D array of Booleans. How do I count how many times True came up?
Message 7 of 12
(3,735 Views)
Maybe this can help, it almost the same code as the above one
Message 8 of 12
(3,729 Views)
FIrst of all, you should start a new thread, because the current thread is marked as solved and this is a new problem.
All you need is the following.
(If the array will be larger than the range of I16, insert a to_I32 before summing.)
Message 9 of 12
(3,721 Views)
This is way too convoluted!
Hmm.... ever wondered what would happen if you would remove the "equal TRUE" and simply wire right across to the select node???? Scratching head....
(See also everything ever posted in the Rube Goldberg thread)
Message 10 of 12
(3,711 Views)
