Count a bool-event (start-stop)
What do you mean with "out of the loop"?
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 21 of 25
(755 Views)
I send you the vi. There is the "stop" in the loop, but I've to put this vi into another vi and there exists the "stop" which I have to use. And so the Stop has to be outside the loop.
Message 22 of 25
(754 Views)
There are various ways to do this.
You can use global variables which are written outside your counter and there just only read. In this case you have to be make sure that you always read the correct value.
Another way is to wire a reference to the counter, if you use a control to stop it. So you can read the value of the control from within your counter.
Thomas
Using LV8.0
Message 23 of 25
(751 Views)
PLEASE send me a picture of the vi how you mean this.
Message 24 of 25
(743 Views)
If you tried it - could you post your code? Or could you explain how you tried it?
Using LV8.0
Message 25 of 25
(739 Views)
