This widget could not be displayed.
Count a case stucture
Hello all,
how I try to count how many times a case stucture is entered. I have the case sturcture inside a while loop and I use an increment together with shift registers. But when the case stucture is entered the increment is exectuted with the while loop frequency. How I can count only once each time ?
(3,854 Views)
Instead of using the loop increment, set the shift register to 0 (zero) outside the loop, then just put an increment (a "+1"),found in the numeric palette,  in the case that you want to count.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,844 Views)
you're almost there....you wanted to count the #s of "true".try using bool crossing and a SR
(3,835 Views)
Ah, Apok understood your requirement a bit better I think.
Putnam
LabVIEW Champion
(3,816 Views)
Your picture doesn't show up in your original post.  It is just a box with a red X.  I don't know how you tried to insert it.  You need to sue the picture of the tree on the tool bar of the edit menu.
(3,780 Views)
Sorry for the picture. I'll try once again. I think the upper solutions work well. Thanks a lot for your respones.
(3,751 Views)
You need to wire through in the false case.
And like Putnam said, put a zero constant to the left hand shift register so it restarts at zero.
Put a stop control going into your while loop's stop terminal.  And put a wait statement in the loop so the loop isn't greedy.
(3,742 Views)
