Count multiple element in a 1D array
Hi LV warrior.
I have a problem concerning manipulating data of an array.
I have an array of elements(numbers), and I want to count the different elements in an array.
Example : Array of  (1,1,1,1,2,2,2,3,3,3,3,3,5,5,5)
I want to have at the end a listbox showing that we have :
4 Times 1
3 Times 2
5 Times 3
3 Times 5
 Smiley Frustrated  I have no idea how. Any insight would be helpful..
Message 1 of 19
(7,471 Views)
@syahid89 wrote:
Hi LV warrior.
4 Times 1
3 Times 2
5 Times 3
3 Times 5
Start learning how to program in LabVIEW.
http://www.ni.com/academic/students/learn-labview/
Message 2 of 19
(7,463 Views)
Hei thanks for the response (I Guess)
My Idea is to split the array containing different element, then calculate size of every newly formed array.
But I do think this idea is not effective, and there must be easier way to do this.
Message 3 of 19
(7,455 Views)
You can use variant attributes. Take a look at this thread 'How to find the mode of an array of strings'.
You just need to convert the numbers in your array to strings because the variant attributes are strings.
Message 4 of 19
(7,435 Views)
Suppose I gave you a list of numbers --- 2, 2, 2, 5, 5, 5, 5, 7, 7 -- and I asked you how many of which numbers there are (but I didn't tell you the answer).  Could you tell me?  Asssuming that the answer is "Yes", how did you work it out?  What steps did you use?  Can you write down the steps?  [This is called an algorithm].
Once you have the steps written down (in your native language), can you see how to do any part of any of the steps using LabVIEW?
Leave the last part of your problem (displaying the answer in a listbox) for last -- figure out the algorithm first.  It is basically a counting problem ...
Bob Schor
Message 5 of 19
(7,412 Views)
Here's a sample of two ways that were mentioned before. Try to get the most of them, and maby find a better solution?
Message 6 of 19
(7,371 Views)
This problem would be a nice candidate for a Code Miniature.  Building an array in a loop disqualifies my solution if you might end up with large arrays.
Jim
Message 7 of 19
(7,352 Views)
Another way using OpenG functions 🙂
Message 8 of 19
(7,317 Views)
That's the way I was thinking.  It won't be the most efficient, but it is usually good enough, and besides everyone already has OpenG installed anyway right....right guys?
Also the OpenG version has polymorphic support for various data types.
Message 9 of 19
(7,310 Views)
Accepted by topic author syahid89
Here is a version which generates a 2D array as output. The first column has the counts and the second column has values. It sorts the input array so there is no restriction on the order of the elements in the input array.  Limitation: Integer data types.
The second case structure handles the two cases where the last two elements in the sorted array are the same or different.
Credit to Bob Schor: After thinking about the issue for a bit I wrote down the algorithm before I started coding.  The algorithm is not spelled out in the VI.
Lynn
Message 10 of 19
(7,266 Views)
