Count pulses in digital waveform
Hello everybody,
I need to count the pulses of a digital waveform. I have looked at the examples related to this, but all of them seem to use a signal acquired by a digital counter input. I already have the signal in my computer, so using a device input makes no sense. And I searched the function library but found nothing. Which LabView functions should I use?
Thank you in advance for your time and help,
Pablo Concha
(11,601 Views)
SOmething like this should work for a simple digital wave.
Tim
GHSP
(11,590 Views)
Thank you for your answer.
It seems to be a Labview 9.0 file and I have Labview 8.2. Could you save it in compatibility mode or at least upload a screenshot?
(11,572 Views)
Accepted by topic author Pavolo
Here you go. 8.2
Tim
GHSP
(11,560 Views)
Hello friend,
Here, i have attached VI... In this VI i need to count the number of cycle in the pulse and also find the pulse count without give the threshold value to the signal(analog & digital).
If you got a solution, that code can  be implemented for all the waveform signals..
could you please help me...
regards,
vignesh R
(10,403 Views)
I have to know number of pulse counts in led by using digital/analog can you please suggest me how to find in LabVIEW 8.5
Regards
Meena
(6,264 Views)
