I want to write the while loop to read the DAQ signal. Each time, the DAQ input signal is compared with the spec. limit. The signal that is within the limit will be recorded as " Pass " while the signal out of spec. will be recorded as " Fail ". At the end of the testing ( I break the program), the testing result will be displayed on the testing panel.
I believe my question is similar to the programming of " A=A+1 ". Can anybody help me to resolve the problem ?
