Count the Rising Edge of output of the Comparator
I want to conut the pulses of the output of the comparator.  I couldnt able find any suitable counter from functions pallate. The counters in that is meant for the devices. So, Pls let me know the methedology for counting the pulses.
Thanks in Advance.
Rgs
Shivaram
(3,097 Views)
What comparator are you talking about? Is it some piece of hardware you have or something in software? What is generating the pulses?
(3,092 Views)
Hi All-
If you're using an NI DAQ board you will need to install the appropriate driver to find counter programming functions on your palette.  For most new devices, you will want to use NI-DAQmx 8.0.  Once the driver is installed you can find examples under Find>>Examples by browsing to Hardware Input and Output>>DAQmx>>Counter Measurements.
Hopefully this helps-
Tom W
(3,080 Views)
