Counter Frequency Write with error 50103
Hallo
Maybe someone can help me, I want to write two PWM signal with two Counter Frequency Single Chanel single sample. But I got the error with 50103.
I have tried a lot methods , but they still do not work. With Single chanel, it works.
Who can explain it? thanks!
(1,553 Views)
What hardware model are you using?
(1,521 Views)
USB 6229
(1,511 Views)
Hi ZYOng
I am using hardware USB 6229 from National Instrument.
I found where my problem with the error 50103 is. But I do not know how to solve it.
Because I am using the same Counter Dev1/ctr0 as Input and also as Output. The Input is used for the speed measurement. The Output is used for PWM signal to generate. You can see the picture below. Do you know how to use one counter for both functions? One is for CO Pulse Freq, another is for CI Cnt Edges. Thank you!
(1,497 Views)
Accepted by topic author Zhangfy
You can't do that.  At any given time, a counter can be configured as an input task OR as an output task but NEVER both at once.
-Kevin P
(1,483 Views)
