Counter Using DAQPad-6016
I have a signal inputting to a counter port of a DAQPad-6016 and I can't get it to count the pulses.  I've attached the LabVIEW code that I'm using.  The confusing thing about this is it works in MAX.
(3,205 Views)
Accepted by topic author Bernadette
Your code should look more like this example.
Best Regards,
John Passiak
(3,200 Views)
Thanks for your help.  I realized, I had the signal connecting to the wrong pin.
(3,188 Views)
