Counter in Toggle mode..
Hello.
I want to  count a digital edge using Counter on DAQ-6036E and generate a pulse every 10 edges.
Thanksfor your help...
(2,846 Views)
You asked a variation of this question which I just answered over in another thread.  This timing diagram is different than the other in that here you are generating short output pulses where the other one produced output square waves.  Do you know which you need?  Does it not matter because only the rising edge of the output pulse is used for anything?  Or do you need the ability to do both?
-Kevin P.
(2,819 Views)
