Counter output using DAQ-assistant and NI 6343
I am using DAQ assistant in Labview in order to use two counter output.
Firstly, I used one DAQ assistant to produce two counter output. The two counter output showed proper result (20180618_7_work.vi), when  I checked the two counter output by using a oscilloscope.
In order to obtain two counter output independently, I used two DAQ assistant in new vi code (20180620_1.vi).
Because of my plan is one counter output continuously works and other counter output works during specific time.
However, when I check the two counter output by using a oscilloscope, time interval between two counter output is not constant (For example, the time interval in 1st measurement was 1ms, but the time interval in 2nd measurement was 5ms.) I don't know exact reason. I think the issue may relate with synchronization.
In order to solve the time issue of the two counter output, how should I do?
Hoping someone may be able to help.
Thank you.
(2,466 Views)
Hi jjo,
Get rid of those ExpressVIs and use plain DAQmx functions
Most of the stuff is explained in the example VIs coming with LabVIEW - 99.9% of them don't use ExpressVIs!
(2,419 Views)
Ok, I understood. I will try it.
Thank you.
(2,407 Views)
