Counter problem
Hello
I'm new to LabVIEW.
I want to make a program to measure RPM by using a switch between AI15 and +5V on the USB-6215. I have setup a program in labview "Sample on demand" and a filter, because when i connect a wire only to the AI15 i get a very noisy signal. But when the USB-6215 is on "sample on demand" the filter doesn't work???? Only in Continuous mode..
Can somebody please look my vi to help me modify the program to measure rpm?
Message 1 of 8
(5,596 Views)
You haven't included your VI
David
www.controlsoftwaresolutions.com
Message 2 of 8
(5,582 Views)
Sorry, here it is 🙂
Message 3 of 8
(5,574 Views)
The filter you are using expects a number of points (for example in the form of a waveform or an array of points), whereas you are passing it a single point.
You could try the following: -
Acquire a number of points and build waveform/array point by point then filter when there are a number of points (you could store the points on a FIFO basis, or filter after all data has been acquired.)
Or, use a filter that works on a point by point basis
David
Message 4 of 8
(5,550 Views)
Also,
it looks like you are measuring a digital signal - if so why have you conected it to an analogue input?
David
Message 5 of 8
(5,549 Views)
Hello
It's because i dont know how to do it :s if you may could help, it would be great. The DAQmx is setup to measure analog voltage..
Message 6 of 8
(5,536 Views)
You can find lots of examples in LabVIEW.
Try Help>>Find Examples then select Hardware Input and Output>>DAQmx
Similarly you can find some filtering examples; Help>>Find Examples then select Aanalysing and Processing Signals>>Filtering and Conditioning
Rather than filtering have you considered adding some hysteresis to your switch level?
David
Message 7 of 8
(5,525 Views)
Message 8 of 8
(5,491 Views)
