Counting edges with dynapar encoder
I am very new to Labview. To kick off some experience, I am trying to count edges on a Dynapar encoder, Model E14020000303. Here is the data sheet:
 https://ecatalog.dynapar.com/downloads/E14_DS_702489_2_.pdf
I am using LabVIEW 2011, with a NI USB-6210 DAQ. My white wire on the encoder is connected to PFI0. The red and black wires are connected to my 5V voltage source. I am rotating my encoder to count the revolutions. Supposedly my encoder is a 200 PPR, and it is also quadrature.
However, I am not understanding what I am getting when counting edges using DAQ Assistant. I am using the Edge Count on ctr0. I can set the DAQ assistant to run on 1 sample acquisition mode and count the rising edge. When I turn the encoder 100 times, the measured value on the DAQ Assistant is usually around 76500, which would mean 765 edges counted per revolution. I can also change things around and go to continuous acquisition mode. I set up PFI2 as the external clock source with a rising edge and put the green wire in PFI2. I set it to read 1 sample at 1k Hz. This usually results in counting around 820 edges.
I don't understand why I am getting these readings. The DAQ Assistant should only be counting rising edges because that is what it is set at. Why am I getting numbers so high?
Thanks!
(4,806 Views)
Does the number vary? You could have a noise problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,787 Views)
Did you connect the ground of your 5V power source to the digital ground connection on your 6210?
-AK2DM
(4,779 Views)
Yes, the number does vary. Would 800 edges counted be correct for a quadrature 200 ppr encoder when it is supposed to be counting rising edges?
(4,743 Views)
No, I did not connect the digital ground connection. I can try that tomorrow. I am learning LabVIEW for work, and I have already left for today.
(4,741 Views)
The ground could easily cause this sort of behavior.
Mike....
LabVIEW Champion
(4,674 Views)
Hey guys,
Sorry for the late reply, I have been put on other tasks. You all were right about the ground, that indeed was the problem. With the daq grounded, the encoder measures 200 edges per revolution.
Thanks!
(4,535 Views)
