Counting from Iteration loop
I am currently using the iteration loop to provide a number to be used in the filename.  I need to format this number to start with 001 and continue to count  in this fashion: 002, 003, 004 etc .  But most important once I get into double digits I still need it to keep a 3 digit code so, 10 would be displayed as 010 and 11, 011.   Any help would be much appreciated!!
(4,151 Views)
Use the Format into String function with format string %03d
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(4,145 Views)
Just use Fornat Into String with %03d as your format string.
Daviid
(4,144 Views)
Snap! (http://en.wikipedia.org/wiki/Snap_%28game%29)
Message Edited by David Crawford on 10-20-2006 12:42 PM
(4,142 Views)
Thank you for your quick response, I am still having  a problem which I am sure is very simple.  I am not sure what to put in the input 1..n connection of the  Format to String Vi connection. I am assuming this is the problem since I have put the %03d in the The format  string connector but  my number count is now 0000, 1000, 2000  rather than 000, 002,003
Thanks again for your help!!
(4,134 Views)
It's really just that simple:
Message Edited by becktho on 10-20-2006 02:19 PM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,130 Views)
You only need to wire the index number to input 1. Your actual outcomes have no explanation, unless you are reversing the string and concatenating a trailing '0'.
Post a picture of your code if you don't succeed.
Paolo
(4,124 Views)
