Counting letters
Ok so here is where I am at now, I am missing something, how do I count the letters? Is there something I am missing in my formula
Message 11 of 19
(2,098 Views)
This is where I am now, I just cant figure out how to count the letters.  I am not sure what to hook the Number indicator up to.  All it has to do is count the how many letters in the persons last name so if it was, Jet Li, last name would be 2.
Any suggestions you have are greatly appreciated
Message 12 of 19
(2,096 Views)
Perhaps a function that is named something like "String Length" would be useful?
Message 13 of 19
(2,095 Views)
If only some genius had thought of creating such a function...
LabVIEW Idea Exchange, here I come!  I can just see all the Kudos flowing in. Pshaw on the improved Boolean constant.
Message 14 of 19
(2,060 Views)
Here's a hint:
You will need the following elements on your front panel: (the grey screen)
A String Control named "Name"
A String Indicator named "Greeting"
A Numeric Indicator named "Last Name Length"
You will need the following elements on your block diagram: (the white screen)
The terminals for "Name", "Greeting", and "Last Name Length"
Three (3) functions from the string palette
One (1) function from the numeric palette
Two (2) String Constants
*NOTE* The suggested number of functions is how many I used to solve your problem.
I'm sure the Knights of NI who have responded to this thread could solve it using fewer functions.
I have decided to make a Rube Goldberg VI for this problem mainly because my tasks are low at work today (i.e. documentation day)
but also to hopefully entertain the aformentioned Knights. (also, couldn't it just be kNIghts?)
Message 15 of 19
(2,040 Views)
this may help,
Using the match pattern, search for the space string charactere, then keep the part before and you'll get your name.
-get the second part and you will get your surname, then use a string lenght to know the number of letters.
NB: you also can have a look at the labview help, using the help menu--> find exemple.
Stoad.
Message 16 of 19
(2,021 Views)
Stoad,
This is homework.  You want to help guide them to the answer, not do the work for them.
Message 17 of 19
(2,016 Views)
@stoad wrote:
this may help,
Stoad.
In the future, please refrain from doing somebody's homework. This is not a homework writing service.
Message 18 of 19
(2,010 Views)
I'll assume the homework is already due, I almost posted this earlier with an evil grin thinking about someone (who needed help with this problem) using it then being forced to explain to the teacher what the code was doing.
Message 19 of 19
(1,939 Views)
