Covert string in SI format to number
I have a number 200,000. I can format it to get a  string in SI notation. If I format it using %.2p , I get 200.00k.
My problem here is how do I convert 200.00k (String) to 200.00k (number)?
Also Labview is smart to convert 200.00k  into 200,000. But can I convert 200,000 into 200.00k retaining the data type?
I know sounds stupid. I am been struggling to do this.
(4,759 Views)
Message Edited by nevil on 08-21-2008 01:28 PM
(4,758 Views)
The display format of a number has no bearing on its value. You can change the display format to whatever you want. E.g.:
Message Edited by smercurio_fc on 08-21-2008 01:47 PM
(4,749 Views)
Use the "Scan From String" function as you would the "Format to String". Those two functions are inverses of each other.
(4,747 Views)
