Coverting a 1-D array of Strings to 8x8 matrix
Hi guys i have a 1-D array of strings but i want to dispaly is as 16x16 matrix. But array to matrix vi does not take strings as input so any other procedure is there to convert it?
Thanks & Regards
Niladri
(3,143 Views)
"Build Array" and "Transpose 2D array" with a String array, works the same way as with "Array to Matrix.vi" and a "Real 1D Array".
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
(3,124 Views)
Hi newbee,
first: using a "matrix" in LabVIEW is intended for mathematics operations. So a "matrix" will never work with strings...
But maybe you just need an 2D array of strings?
Or do your strings contain numbers and you need to convert those numbers to DBL representation?
Hint:
Whenever you have specific problems you should attach a VI showing what you have programmed so far AND showing which data you are talking about!
(3,116 Views)
Thanks everyone for their response. And @GerdW yes you are right all I need a 2D array of Strings and I made it using "Reshape Array".
Thanks & Regards
Niladri
(3,110 Views)
Hi Newbee,
your snippet looks overly complicated to me:
(3,102 Views)
